Need strut boot/bellows
Old Nov 1, 2017 | 04:36 PM
jackhammer's Avatar
Car: 1987 Camaro RS
Engine: V6
Transmission: Automatic
While replacing my front struts I had to remove them to cut off the top nut. While I was doing it the broke the boot, dust cover. bellows or whatever it is called. It was old and cracking anyway but I jacked it up more. Does anyone know where I can find a replacement? It doesn't have to be original, just has to fit and work. If I can find one at a local store that would be the best. thank you.
1987 RS V6
Old Nov 1, 2017 | 05:32 PM
W.E.G.'s Avatar
Car: 88 Sport Coupe Camaro
Engine: V6 2.8
Transmission: Borg-Warner T-5
Axle/Gears: RPO/GU6: 3.42
Re: Need strut boot/bellows
Old Nov 1, 2017 | 05:41 PM
Those are SOOOOOOOPER generic.
Look it up at Rockauto or something. Monroe, Rancho, Bilstein, etc. I bet ALL make something that will work.
Old Nov 1, 2017 | 05:42 PM
W.E.G.'s Avatar
Engine: V6 2.8
On the subject of third gen strut dust shields, it is worth being aware that the factory shield acts as a sort of thrust washer between the top shoulder of the strut-shaft and the underside of the strut tower.
In that context, it also acts as a spacer.
I wonder how many leaning third gens we've seen going down the road, where the reason for the lean was the abence of the thickness of the dust shield on the strut on one side of the car?
OP, unless the damaged shield is demolished altogether, you might want to consider getting out the epoxy, and re-build the damaged part. Mine had lots of cracks, so I used JB-weld on the ouside and the inside of the shield. If you do this, be aware of how the shield contacts the underside of the strut tower, and the top of the strut shaft. You want no more than a thin, even layer on any engagement surface.
Old Nov 1, 2017 | 06:34 PM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
Since both of my cars have had the strut towers replaced with spherical bearings, I just use generic Rancho soft boots. Works great.
Old Nov 4, 2017 | 10:56 AM
Ghettobird52's Avatar
Car: 88 Firebird Formula
Engine: LO5 5.7 TBI/Ebl Flash
Axle/Gears: 2.73 stock rear end
It really doesn’t matter what you use, or if you actually use one at all. It’s just a dust cover. I’ve never seen a third “lean” like WEG is saying...
When I re did my suspension couple months back I went with founders strut mounts so I didn’t put any back on.
Old Nov 9, 2017 | 02:05 PM
jackhammer's Avatar
Car: 1987 Camaro RS
Engine: V6
This is what I ended up doing (for now anyway). thank you.
BTW the top nut was a bitch on both sides. I ended up having to cut them in half with a Dremel tool to remove them.
Old Nov 9, 2017 | 03:34 PM
W.E.G.'s Avatar
Engine: V6 2.8
Thanks for getting back to us on this.
Keep us posted on how the repair holds up.
Mine is going strong - only a week and maybe 50 miles since the repair, but hey, you gotta start somewhere.
Cheers!
