Guys Help Quick!!! i Need The Car, Except Theres Something With The Rotor!
Old Jan 4, 2002 | 03:06 PM
FiReBReTHa's Avatar
ive never delt with this, its flipping me out,
drivers side rotor i can grab it and WOBBLE IT it wont fall off... but it WOBBLES???!! WTF damnit guys, i just picked up new toys and now that happens, the tires off right now in the front driveway.... what is it? how can i fix it? please guys, any ideas???
THANX!
Old Jan 4, 2002 | 03:38 PM
ATOMonkey's Avatar
What happened is probably the center spindle nut has come loose. The procedure for tightening it is well explained in any manuel but here's the abreviated version.
Remove the spindle cap(small round piece on end of rotor)
use a screw driver to pry it off carefully
Remove cotter pin from spindle(this is probably broken and you'll need a new one even if it isn't)
Remove locking cap on top of spindle nut
Tighten spindle nut to "tight" with pliars and then back it off a half of a turn. The whole goal of this is to make sure the rotor is seated tight on the bearings, but not so tight that rotation of the rotor is impeded. It should not wobble, but it should also spin freely. There is a specific torque for this(~5 ft-lbs), but I can't remember exactly.
Then install everything. You might have to tighten the spindle nut slightly more to get the locker to line up with the whole for the cotter pin in the spindle.
Everything should be OK now.
I should also say that the bearings should be inspected to make sure that they haven't gone dry or been damaged while this was happening.
Old Jan 4, 2002 | 05:11 PM
FiReBReTHa's Avatar
THANK U SO MNUCH!!! sorrycant type well, ggrease on hands
ok i got the cap off theres a funky six pronged object on a screw, im goin to try tightening that,because thats wehat my best guess is because iremoved the plate from behindthat and only saw a flat surfaced object. thanx again, i have a good chanceat making it to work!!!!
Old Jan 5, 2002 | 02:59 AM
RSpeed's Avatar
Car: 92 Z, 91 Formula, 04 CTS, 01 Tahoe
Engine: 355 forged 4 bolt, SuperRam, 58mm t
Transmission: T5, looking for t-56
Also,if your bearings are in bad shape then your hub/rotor assembly will be loose.
Old Jan 5, 2002 | 03:45 AM
Jza's Avatar
Jza
was there a cotter pin? you should put one if not, otherwise you'll be doing this again in a few weeks. may want to repack the bearings too.
Old Jan 5, 2002 | 08:12 AM
FiReBReTHa's Avatar
cotter pin wasnt bad,
proj is not complete,
ok, theres the cap, then there was the screw, ,then the prongled nut, then a plate, then something behind all on the spindel screw...
i tried tightening the pronged nut but nothing came of that, it got stuck and wouldnt move on, because of the last piece on the spindel, do i have to remove caliper and rotor to do something? im baffeled,
right now im pissed at family/friends,
sell the bird my ***... lol
Old Jan 5, 2002 | 09:44 AM
FiReBReTHa's Avatar
Dood Wheres My bearings????
this is WACK, im not understanding where they can be, because im looking at it, and the...................
just found a chiltons for a silverado.... ok, this problem might be larger then observed.
does anyone know what size torque bit it is for the caliper?
remove caliper, pull bearings check the shape, see if the rollers are in it, cause that could be it...
Old Jan 5, 2002 | 04:17 PM
RSpeed's Avatar
3/8 hex bit.
1992 Trans Am
May 10, 2023 07:19 PM
Jorlain
Aug 24, 2022 05:11 PM
specialized
Jun 18, 2022 09:26 AM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
