Does it look like i need new rear shocks?
Old Feb 17, 2018 | 04:51 PM
1985CamaroSport's Avatar
Does it look like my rear is too low or is my front too high, first time driving car since it sat and i did a launch or two, its just a little 2.8 though. Just want some opinions before i replace rear shocks, car has 21k
Old Feb 17, 2018 | 05:01 PM
Re: Does it look like i need new rear shocks?
Yes you need rear shocks.
Doesn't matter about "look". Can't tell that way regardless, since shocks don't affect ride height. Just change em out. Total piece o cake. You won't BELIEVE how messed up and useless those factory ones are and have always been, once you put ones on there that actually DO something and aren't just acoupla pounds of dead weight.
Swap the rear springs while you're at it, they'll fall out anyway when you undo the shocks, might as well pick up new ones and put those in as go chase the old ones as they roll down that slope and pick those up instead. They'll make the car sit more level besides. Get Moog CC635.
Put in all new sway bar end links (2¼" or 2½" poly such as Energy Suspension or Prothane) and sway bar bushings. You'll need to measure your bars for bushings to be sure you get the right ones, but they're probably 32mm (1¼") and 22mm (use 13/16" if that's what they measure). Use poly and greasable, NOT stock replacement such as Moog or AZ el cheeeeeepo.
After you do that you WON'T BE ABLE TO WAIT to change out the front struts. They're the equivalent of the shocks on the rear.
Old Feb 17, 2018 | 05:37 PM
So what would make the rear sit so much lower after a day of driving? Also my car has rear leaf.
Old Feb 18, 2018 | 02:27 PM
Lurbie's Avatar
Car: 89 Camaro
Engine: Dart SHP 400-Holley Terminator EFI
Transmission: Tremec T56 Magnum F
Axle/Gears: Strange S60 3.55:1
What???
Old Feb 18, 2018 | 03:12 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
If it is you have larger problems.
Old Feb 22, 2018 | 08:00 AM
turboguard's Avatar
Car: 1985 Pontiac Firebird Trans Am
Engine: 305 LG4
Transmission: 700R4 Automagic
Axle/Gears: No clue
I demand pics. For science.
Old Feb 22, 2018 | 08:16 AM
Wore-out sagging crappy used-up old worthless stock springs. Although I will say, if they sag noticeably more each day, then they're even more wore out than usual. Won't be too long before the body is sitting on the bump stops.
No it doesn't.
Just do what I said. No sense in arguing about it and thereby making yourself look like an idiot. Replace the shocks and springs. You'll be AMAZED at how much difference it makes.
Old Feb 22, 2018 | 08:19 AM
TBRays98's Avatar
Car: 1989 Formula
Axle/Gears: 3.45 1LE Disc LSD
lmao, for science!!!
Old Feb 22, 2018 | 05:08 PM
Sorry it appears i just went full retard, never actually paid attention to the rear coils until i did the rear shocks yesterday. We have a 71 and 81 so i was expecting leafs. Embarrassing, but anyone have a clue on what i could've done to make the front end sit higher?
Old Feb 22, 2018 | 05:12 PM
Yes i realized i was wrong as soon as i jacked it up, but anywho, the front wheels have positive camber like the engine is pulled out. The rear shocks were toast tho. But i am starting to think the previous owner may have replaced the front springs with v8 springs and i am just now paying attention to it.
Old Feb 22, 2018 | 05:18 PM
MY87LT's Avatar
Car: 1987 Camaro LT
Engine: LG4 w/ SLP headers & a 3" catback
Transmission: THM700R4 (Stock)
Axle/Gears: Stock 2.73 gears. No Posi
Clean sport coupe you have there.
Old Feb 22, 2018 | 06:07 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Do the front struts work? I have seem them fail and stick in the out position. Maybe worth a look, just bounce the front and see if it moves or if it's solid.
Old Feb 22, 2018 | 06:56 PM
The front end will go down if i put my weight on it, but it seems pretty damn stiff.
Old Feb 23, 2018 | 06:52 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
looks the front has been lifted off the ground and set back without moving it around some to get the wheels back where they need to be.
as the front of the car is moved up and the suspension articulates, the top of the tire wants to swing out. if it's lifted off the ground it will. when it's set back down the suspension stays in this positive camber position until it rolls around some or the friction between the tire and the surface is otherwise overcome.
you'll also notice some deformation in the side wall when this occurs. it's a product of the suspension geometry.
Old Feb 23, 2018 | 07:21 AM
After i changed the oil, i drove the car around for atleast 20 minutes and the front height stayed the same.
Old Feb 23, 2018 | 07:51 AM
RedLeader289's Avatar
Car: 1983 Z28
Engine: 385 Fastburn
I'd swap the front struts and see how that goes. Maybe the previous owner told the autozone guy he had a 2.8 and the clerk heard v8.
Old Feb 23, 2018 | 10:08 AM
I have a photo of the car when i picked it up, front end is definitely higher up now than before, so i f*cked something up somehow unless they are stuck up which is very unlikely.
Old Feb 23, 2018 | 05:02 PM
Struts don't change the ride height, at least not very much; maybe 1/8" in extreme cases. Just like shocks.
Springs hold up (or not) the car.
It may take acoupla days for the front to settle back down, but eventually it will ... and then some.
The front actually looks about the right height. The rear is sagged about 1½". Which is usual... you DID change them, right??? Since you saw how EEEEEEEEEEEZZZYYY it is especially? ESPECIALLY when the shocks are already out? Did they physically fall out on their own, like usual?
Old Feb 23, 2018 | 08:55 PM
I did not replace the rear springs, they did not fall out when i did the shocks, to do the springs i could just take the bottom shock bolt out right? because i do not feel like ripping my carpet up again.
Old Feb 24, 2018 | 07:06 AM
Yup, that's it... might want to unbolt the brake line banjo fitting from the top of the pumpkin also, to give the hose a little slack; that rubber brake line might well have been the only thing holding the rear up and keeping the springs from falling out. Not a healthy thing to do to the rubber hose.
Old Feb 24, 2018 | 10:20 AM
TylerSteez's Avatar
Car: 86 Trans Am WS6
Engine: 383 stroker
Old Feb 24, 2018 | 01:00 PM
Just ordered the rear springs, the moogs you suggested. Will see how much that helps when they arrive.
Old Feb 24, 2018 | 06:23 PM
Good move. You'll like em. You'll be happy.
USA1 82Camaro
Mar 25, 2013 11:27 PM
rich14
Apr 23, 2009 06:17 AM
grafx
Oct 28, 2004 02:34 AM
HALLSRESTO
Feb 29, 2004 09:07 PM
