Baer brake pads
Old Jan 7, 2002 | 09:39 AM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
Baer brake pads
With a bit of luck i will be picking up some their track setup. It is used so i would like to put new pads in. Do i have to go directly through Baer for pads or can a get them elsewhere?
Has anyone sucessfully put the track system (13") rotors on 89 WS6 rims? If not then i guess its time for some 17" rims
Old Jan 7, 2002 | 11:24 AM
powermite's Avatar
Car: Transam
Engine: ZZ4,Holley Stealth Ram,Commander 950
Omega,
Exciting times for you then.Ive got that system on my 85 Transam and the whhels just interfered with the calipers.Maybe your might just fit.I could have made mine fit by grinding a bit of the caliper away but i didnt want to risk it.If you are buying new rims then go for 18"s as they look so much better.Whichever way you go you wont be dissappointed with Baer.
As far as pads go,they are available direct from Performane friction ,no problem.They even sent them over to the UK for me.
If you want any more ifo,then email me direct.
cheers
powermite
Old Jan 7, 2002 | 12:12 PM
Omega's Avatar
Engine: LS1 / LS3
A brit with a TA.. brave man. Those country roads must be fun... until you have to move over for oncoming cars.
I don't mind grinding a little off the caliper for clearance. I wouldn't go for 18" rims for the roads in New Jersey are hell on my alignment as is.
Thanks for the info!
BADNBLK
Convertibles
Sep 21, 2015 07:56 PM
dbrochard
Sep 19, 2015 08:13 PM
84 TA NV
Sep 6, 2015 08:02 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
