drag racing?
Old Sep 5, 2018 | 06:48 PM
bensbaby's Avatar
Car: 1988 GTA Trans am 1 owner since new
Engine: 383 built
Transmission: 1995 camaro t56 6 speed
Axle/Gears: 3.24 posi 9 bolt
drag racing?
I have a 88 gta
383 sbc and a soild 9 bolt
now I want to make the launch at the track
like slicks and try to get front up
and do I have to take all my gta swar bars off front and back
is there any thing else I need to know
ty
Old Sep 11, 2018 | 05:21 PM
howie099's Avatar
Car: 1986 Firebird TA
Engine: SBC 350
Transmission: TH350 Stage2
Axle/Gears: 9 Bolt rebuilt w/3.70
Re: drag racing?
don't need to remove sway bars. 9 bolts are stronger than 10 bolts but they have limits. Make sure your 9 bolt is adjusted and shimmed right before you beat it most would need new cones if you have a bunch of miles on them. Try some DOT street slicks. You might need a driveshaft loop depending on how fast you go now.
Old Sep 11, 2018 | 08:57 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: drag racing?
I pushed a 3.27 geared 9 bolt into the high 11's with a 383. Car wasn't street legal. Gears were wrong. Needed something like 3.73. With the 3.27 gears, I was going through the traps just as I was starting to make power in high gear.
Don't invest a lot of money trying to beef up the 9 bolt or even a 10 bolt. It's not worth the money. No matter what you do, you'll still have those tiny ring and pinion teeth.
Although it's an expensive option, a bolt in 9" or 12 bolt is a better choice.
Old Sep 12, 2018 | 10:49 AM
howie099's Avatar
Engine: SBC 350
Re: drag racing?
I did all u can do with 9 bolt. Rebuilt the unit w/ new cones. Welded the tubes. 3.70 gears, support cover. I bought the diff w/gears used with low miles. So for like $700 it was much cheaper than getting a 9” or 12 bolt. Since you would have to figure in the $2500-$2600 for a complete drop in axle and all new rear brakes so you are really talking $3000 to switch.
the 9 bolts can handle 500-600 wheel HP. The axles usually break before the diff if u keep on adjusting it to keep it tight.
I when u start creaping to the 10’s in 1/4 mile time the switch.
Go Blue
Nov 25, 2018 11:29 AM
