Adjustable Panhard Rod Relocation Kit
Car: 88 gta
Engine: 5.8
Axle/Gears: 3.73 POSI
im looking into buying the Adjustable Panhard Rod Relocation Kit.has anyone on here bought this set up?i would like to know how u determine where to set the bars at for this seeing how there is 3 slots u can set the bars at
Car: '84 Trans Am
Engine: 357 SBC
Axle/Gears: 10 Bolt 3.73, Torsen Diff
Re: Adjustable Panhard Rod Relocation Kit
Someone else should probably confirm this before you take it as gospel, but if I remember right you want the panhard rod to be parallel to the ground when fully adjusted and at ride height.
Car: '89 Formula
Engine: LS2
Transmission: 4L65E
Axle/Gears: MW 3.42 12 Bolt
I would suggest a very slight angle at ride height, so that with a little compression it is then parallel.
Bolt hole placement is found by the seat of your pants, not your head. Each car is different, and rear springs have a strong relationship. The lower you go with the PHB, the stronger the spring needed (then smaller sway bar as well).
Go slow - small increments. This is a terrific mod to do, and you will learn a lot along the way.
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Unless you are at OE ride height with newish rear springs the bracket that only lowers the passenger side is usually detrimental to performance since you end up with that side being too low. The driver's side is usually used if you have a low riding car. Both sides are used when you get heavy into cornering performance and/or you have a lowered car in conjunction with using the passenger side lowering mount to gain exhaust clearance.
Here is my car, lowered and with the passenger side Panhard bar mount lowered to gain exhaust room.
Here it is sitting where it should be after making my own driver's side bracket.
83 Crossfire TA
May 11, 2013 10:33 AM
1irocz2nv
Apr 30, 2007 12:40 AM
Scott_92RS
Feb 24, 2001 03:29 PM
