Torque Arm
Old Jan 11, 2002 | 02:44 PM
JungleJim's Avatar
Torque Arm
How do I run a Trans that is not equipped to bolt one on?
Old Jan 11, 2002 | 06:03 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Torque Arm
You can use an adapter kits available for some transmissions to attach the torque arm, otherwise you'll have to change to a ladder bars or some other rear end arrangement.
Old Jan 11, 2002 | 07:57 PM
SteveSpohn's Avatar
Our torque arms mount to our supplied transmission crossmember, not to the transmission. Check out our website.
Steve
www.spohn.net
Old Jan 11, 2002 | 11:19 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Oh yeah, of course... totally forgot about Steve's torque arms, and I even have one.
Old Jan 12, 2002 | 08:25 AM
JungleJim's Avatar
Steve
www.spohn.net
You've got an impressive site and selection of parts. I would very much like to do business with you. I'm building a Camaro VERY similiar to your Z28, while were in the planning stages right now, your company was just included in the plans.
I'm planning to build a low 12/high11 sec car and would like to use the stock rear for some time with gears and a mini-spool. I have figured out that the "Torque Arm Suspension" was/is one of my major stumbling blocks...........until I saw your set-up.
I read were a guy is running 10.60's with a "stock" rear as well as others.
This car is a budjet build, as I currently run a Street/Strip 70SS396 Chevelle (12.60's) and wish to keep it as a street car (I'll put the factory buckets and stereo, etc. back in it) So, the decision was made to go with the '85 Camaro over the '72 Chevelle also, sitting in the yard. I think the Camaro will be a better platform for a Strip only car than the Chevelle. While the Chevelle has a full frame, I think once I tie this one together it'll be stiff enough, this uni-body stuff is not what I'm used to. Also, I feel like the Camaro will be a more stable ride on the big end, not to mention the 25 years on advancements built right into it.
I plan to strip the interior, ac/heater, crash bumpers,etc.etc.......How much does your car weigh?
no green
Jan 9, 2016 09:22 PM
darwinprice
17
Oct 11, 2015 11:51 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
