Braking was good, now is terrible.
Old Jan 12, 2002 | 10:25 PM
Spifz's Avatar
Car: 1986 Z28 / 2012 CLS550
Engine: F-1R -> Aluminum block 540
Transmission: T56 Magnum + GForce gears
Axle/Gears: Ford 9" 3.00's + Eaton Truetrac
First, here is what I have:
1986 Z28 with stock disc brakes up front. 12" Baer 1 piston brakes in the back. I didn't put the proportioning valve in, because I think if I can't lock up the back brakes, I shouldn't need to reduce the pressure to the rear. I replaced the front rotors recently. Pads are in good shape, semi metallic up front, and whatever came from Baer in the rear. I have some extra weight up front(BBC) And 255/50 R16 Kumho tires all around.
After the rear brake install, braking was very good in my opinion. I did a good solid stop from 60mph brakes only in 105 ft. (I paced it off, so it could be off a little)
Here is the problem. The braking sucks now. Is it possible that when I replaced the front rotors, I screwed them up or didn't break them in correctly? I can't say for sure whether the braking quality degraded after the replacement. When I push the brake pedal, it goes about 30% down, and then gets solid as a rock, almost like when I forgot the vacume hose... Sometimes, after I drive over a harsh bump, the pedal will go all the way to the floor when I brake. I know that all my lines are good and not getting pinched smashed.
Sorry its so long, wanted to give the best info possible, thanks.
Old Jan 12, 2002 | 10:44 PM
ChevyLuva3's Avatar
Dunno man... sweet rims, they look like mine, well sorta.
Old Jan 12, 2002 | 10:55 PM
Spifz's Avatar
Yea, I had to take the picture of the side where my label ripped off the center cap...
Yea, I'm proud of those wheels, paid $235 for all four, very nice condition, road tripped to N. Virginia one night with some buds to pick them up. 11:00pm I called the guy with a cell from his driveway. He was asleep, and we watched the lights come on before he answered... He was really nice about it, considering...
Old Jan 13, 2002 | 05:39 AM
ANDYZ28's Avatar
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
Start By replacing the master cylinder. If you still have the original brake booster then I suggest replacing that also. I think Wagner makes a combination unit that comes with the Brake booster and M/C.
sailtexas186548
Jan 19, 2016 12:21 PM
redmaroz
Aug 16, 2015 11:40 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
