Soft/Sport/Touring Steering Rebuild Kits
Old Jun 20, 2021 | 04:22 PM
ZMWojnar's Avatar
Car: Electric Blue '92 Camaro RS
Engine: 305 5L V8
Transmission: 4 speed auto w/ overdrive
Axle/Gears: 10 Bolt w/ 3.73 gearing
Hey everyone,
I'm pulling my steering box so I can rebuild it. It has lots of slop and the on-car adjustments just aren't cutting it. I know I have the stock F41 box in my car, so the 12.7:1 box.
My question is, what are the differences (if any) in the rebuild kits that are for the soft vs sport vs touring suspensions? When I look on Rock Auto or Summit, all of the kits are differentiated. The only real difference I can see from the pictures is that the soft kits tend to come with the bearings and the sport ones do not. Is there something that I am missing? I haven't taken my box apart yet, so I have nothing to compare to. Trying to order preemptively.
Rock Auto list
Edelmann Soft Kit
Sunsong Sport Kit
Old Jun 26, 2021 | 10:41 AM
Re: Soft/Sport/Touring Steering Rebuild Kits
To the best of my knowledge, there is no difference in the "kit", apart from which model of box it fits. By "model" I mean, the one with 4 bolts holding the cover on, the one that uses a big snap ring to hold the cover on, etc.
AFAIK all of the gearboxes on these cars use the 4-bolt setup, at least in V8 cars. Either of the kits in your photo should fit them. The only difference between them that I can see is that the one includes the lower bearing for the Pitman shaft.
Old Jul 10, 2021 | 06:07 PM
ZMWojnar's Avatar
Engine: 305 5L V8
So, just to confirm, I grabbed the Edelmann kit with the bearings. It all fit properly. Though the pitman bearing that came in the kit was the older style with no shoulder. I ended up reusing the original bearing there. It didn't have any play and the pins all looked clean. I prefer to have the peace of mind knowing it won't get pushed up too far into the gear body. That was the only part that I reused though.
T/Atime
Jan 9, 2021 08:14 PM
UglyTv
Jun 3, 2020 07:29 AM
Spdfrk1990
Nov 18, 2004 07:27 PM
FIRECHICKEN
Jan 15, 2003 08:47 AM
james_fearn
Feb 1, 2001 10:06 PM
