traction
Old Jan 17, 2002 | 08:45 PM
camaro03's Avatar
Car: 1982 camaro
Engine: built 355 chevy
Transmission: th 350 w/ 3.73 gears
traction
I have an 82 camaro with a 2.73 rear end, limited slip, a th-350, and a 3000 stall, i am about to pu ta 400+ hp 350 in it, what could i do to get traction, keep in mind this is a street/strip car, and a daily driver so a little bit of gas mialage is important, i was thinking, air shocks and about 12 inch radials, would that help, i also heard something about something you put in the rear that can make it a posi, any help is appreciated, thanks
Old Jan 18, 2002 | 08:36 AM
82camaro's Avatar
Car: 82 camaro SC
2.73's and a 3000rpm stall converter are going to cause some major slipping and heat in the tranny--hope you have a good cooler.
limited slip=posi.
You will have better traction with good, high quality, tires that fit correctly than huge wide tires with air shocks.
CarGuyDennis
137
Dec 6, 2016 11:02 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
Numbah-1
Sep 12, 2015 08:57 PM
dbrochard
Sep 7, 2015 09:41 AM
IROC Z Z28
Aftermarket Product Review
Sep 9, 2001 11:06 PM
