Strut Tower Brace
Old Mar 8, 2022 | 08:13 PM
Roorancher's Avatar
Car: 91 TA Vert WS6-94 TA Vert
Engine: 5.0/5.7 LT1
Axle/Gears: 2.73-3.42
Strut Tower Brace
Been reading a good deal about Strut Tower Braces lately. My Vert already has welded sub frame connectors. Is it necessary, and is one brand better than others?
i see them on Ebay, Summit, Jegs etc.
TIA.
Old Mar 8, 2022 | 09:25 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Strut Tower Brace
Maybe after market strut mounts before the brace.
https://www.thirdgen.org/forums/susp...wer-brace.html
JamesC
Old Mar 9, 2022 | 07:31 AM
Abubaca's Avatar
I agree with buying strut mounts before buying a brace. That being said, I had already installed the strut mounts, and when I got around to adding a 3 pt. brace, it made a noticeable difference in the rattles/squeaks. Could I FEEL a difference? -No. But I'm sure it helped.
Old Mar 9, 2022 | 09:17 AM
vinny R's Avatar
Car: 1991 Z28
Axle/Gears: 3:42 Auburn
I too have a vert with welded subframe connectors. I had to remove my UMI STB to do some engine work. I have new but OEM strut mounts. I drove the car to test the work out before I put the brace back on. There was a noticeable difference. The car cornered much better and not as much body roll as without it. And just like Abubaca said, it reduced the noise from the front end. I can't say weather one brand out classes the other or 2 point vs. 3 point but what I can say is my UMI is well built and is strong. I would stay away from a bargin E-bay special.
Old Mar 18, 2022 | 05:44 PM
McLovin1181's Avatar
Strut tower braces are one of those disputed areas on 3rd gens.
you can make the argument they are unnecessary for a 3rd gen. The major stress in the front suspension and steering all goes through the front frame boxes & the giant K-member.
that's why wonder bars work so well on our cars.
That being said, I run one.
makes engine work a bit harder as the brace has to be removed before you can change things like intakes ex ex.
The way I think of it-
worst case: it doesn't do anything and adds 8 lbs to my car.
Best case: keeps my frame from commiting suicide when running race tires on all 4 corners
I have a video installing the DSE brace if you are interested.
https://m.youtube.com/watch?v=vnJ-GNsBp_0
Old Mar 19, 2022 | 10:48 AM
Dueling73s's Avatar
Car: 73RS, 85 Iroc, 11 GT
Engine: 383FI, 406 FI, 5.0
Transmission: TKX, TKO600
Axle/Gears: 10 Bolt 3.73s, Strange 12 bolt 3.73
I have a T-Top car and I think they need all the help they can get. It might be a pain for engine work but a 3-point brace is far superior
if it will fit with your intake set-up. Admittedly I run front coil-overs as well which makes the 3 point even more necessary. I have also added
inner and outer frame connectors. Car is in progress so I have had limited miles but when pulling in my driveway it no longer sounds like the
windshield is going pop out lol.
Edwardgp
Fabrication
Aug 1, 2012 11:34 AM
deltaheavy777
Feb 3, 2009 07:37 PM
GEOFF1983Z28
Jun 16, 2007 07:18 PM
