STRUT MOUNTS
Old Jul 28, 2022 | 08:48 AM
gt4373's Avatar
Transmission: 5-Speed Manual
STRUT MOUNTS
What Is The Need For These Under The Strut Mounts
Old Jul 28, 2022 | 09:28 AM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
Re: STRUT MOUNTS
First time I've ever seen those...
Old Jul 28, 2022 | 12:12 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: STRUT MOUNTS
Those are often included with the ebay units to keep the shock travel length the same as stock. You are running OEM style mounts which do not need that spacer. In fact, I am running the ebay specials (UMI wouldn't clear my brake master) without those spacers. The front strut is compressed maybe an inch over what it should be. It looked better and I am not sure if it really matters.
If you want the same strut travel, you'd need to run the spacers under this style mount.
Old Jul 29, 2022 | 02:46 PM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
Re: STRUT MOUNTS
For my front suspension I was considering doing this as it makes sense to regain some strut travel when lowering the car, but decided to follow some advise from someone from FRRAX.com and that it wasn't really needed, I'm guessing it is/was necessary to some depending how low the car is maybe?
Raising Upper Strut Mounts - Third Generation F-Body Message Boards
Post #88 on FRRAX.com
Suspension Advice - F-Body Road Racing and Autocross Forums (frrax.com)
Old Aug 13, 2022 | 10:22 PM
seiplentz's Avatar
Car: 85 Z28
Engine: GMPP 350 HSR
Axle/Gears: 4th gen 3.42 Posi LS1
Re: STRUT MOUNTS
I couldnt run the UMI plates either with a Wilwood master setup. I ended up using QA1s camber caster setup with their coilovers.
FGCUcamarodude
Feb 27, 2019 03:41 PM
88fastgta
May 24, 2010 05:58 PM
SLP IROC-Z
Mar 8, 2005 04:27 PM
GCR_IROC
Oct 9, 2003 03:40 PM
formul8!!
Dec 6, 2002 11:36 AM
