Stock swaybars
Old Feb 15, 2023 | 10:56 AM
MichiganWildcat's Avatar
Car: 1985 IROC Z
Stock swaybars
I know it was on here before but I can't find it now, I have a stock 1985 iroc and want to replace the swaybar bushings and links. From what I see, the links are the same front and rear. But, the bushings obviously need to be the right diameter.
I have failed in many search strings to come up with a definitive answer on stock iroc bars. I'm counting on my 3rd gen family to give me the straight answer.
Thank you
Old Feb 15, 2023 | 02:37 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: Stock swaybars
If you have openend metric wrenches, just slide them over the bar in a semi flat/strait area.
​It'll be something like 34-35-36 for front and 19-24 for the rear.
Old Feb 16, 2023 | 08:06 AM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
Re: Stock swaybars
These can be easily measured with a set of calipers, If you don't have a set Harbor Freight has them cheap, not great for measuring critical tolerances but good enough for figuring out what size sway bars you have.
RGV 89 GTA
Oct 16, 2023 01:22 PM
nheller76
Aug 29, 2012 01:00 PM
SmallTires
Jul 24, 2006 08:53 PM
JamesC
Feb 25, 2001 02:22 PM
