Iroc sway bar diameter?
Old Jul 23, 2006 | 10:54 PM
SmallTires's Avatar
Car: 1984 Camaro Z28
Engine: Roller 350
Axle/Gears: built ten bolt 3.73's
Well in recent travels I ended up picking up a decent 89 iroc parts car. I plan on kicking most of the suspension over my driver car to replace my worn Z28's suspension. I noticed the front sway bar is quite abit larger then my stock item and I was wanting to replace the bushing with poly units from spohn. I did a few searchs on here, however none seem to provide me with the particular info regarding what the diameter of the stock bar is. So what is the stock diameter so I can get these beasts on the car ASAP?
-SmallTires
Old Jul 24, 2006 | 06:15 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Probably a 34 or perhaps a hollow 36. See if you can find a small drain hole near the end link. If so, I'd say 36, though a hollow 34 was manufactured as well. To make sure what you have, put a cresent wrench on the bar in several places, then measure the distance between the jaws.
JamesC
Old Jul 24, 2006 | 11:26 AM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
there is a 34, 35 , 36 . Was it just a coin they flipped on which cars got what ? I think my IROC has the 35 mm.
Old Jul 24, 2006 | 11:52 AM
JamesC's Avatar
To my knowledge, GM never made a 35--at least not one that equipped a Camaro.
Here's a link that may be helpful:
https://www.thirdgen.org/forums/faq-...-sway-bar.html
JamesC
Old Jul 24, 2006 | 08:14 PM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
JamesC
4th gen 1LE's had a 35mm bar.
Old Jul 24, 2006 | 08:50 PM
JamesC's Avatar
Perhaps, I should have said thirdgen Camaro (I have no idea about fourthgen cars).
JamesC
Old Jul 24, 2006 | 08:53 PM
yuel's Avatar
Car: 91 z28
Transmission: 4l60
when and what year did 4th gen ever have 1LE??
Frozer!!!
Jan 19, 2024 04:55 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Warlocksirix
Sep 3, 2015 12:26 PM
ProtoMaster22
Aug 26, 2015 07:50 AM
