fourth gen frontend swap?
Old Jan 21, 2002 | 02:45 PM
slayer2000's Avatar
Car: 1990 GTA
Transmission: manual/t56
I read that the major difference between 3rd and 4th gen front suspension is the steering setup . My question is can the subframes be swapped and if so is there big difference in handling? I read that rack and pinion steering on the 4th gen is better than the stock 3rd gen setup. Any thoughts?
Old Jan 22, 2002 | 04:00 PM
slayer2000's Avatar
Car: 1990 GTA
does anybody have any thoughts about this?
Old Jan 23, 2002 | 12:14 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Yes. Forget about it. There is much more different than just the rack and pinion steering vs. worm & sector ours has. Compare the two in detail and you'll see. Thirdgen: McPherson strut (no upper A-arm), First, Second & Fourth gen's: Upper and lower A-arm suspension and shocks. Yes you COULD spend a lot of time and money converting your superior cornering front suspension to the more supple riding front suspension, but inferior cornering FourthGen version. But, if you really wanted to, it's a lot cheaper just to sell yours and just by a newer F-Body. But either way, have fun with your car. IMO, it isn't worth it. Lon.
Old Jan 23, 2002 | 06:30 AM
LottaBallsCamaro's Avatar
Ionsal=The macpherson strut setup is inferior to a Sla, the roll center way way more controlable, the springs and shocks are allowed to be placed in a better position, the camber is way more controlable, plus you have the added benifit of a much more responsive, tighter, lighter steering system.
Old Jan 23, 2002 | 02:59 PM
SpeedCat86's Avatar
Car: '86 TransAm WS6
Transmission: Custom TH700R4
I will agree that a SLA setup is generally superior to a McPherson strut, but NOT the SLA setup from a 4th Gen. Yeah, rack&pinion steering is nice, but there are other ways.
L.B.C= You mention Camber control, but I was just crawled under a '97 RS and I can't figure out how to adjust the thing without dismantling the suspension. Maybe dropping $600 for some of LG's adjustable A-Arms.
A Third Gen McPherson Strut, while not ideal, is certanly easier to adjust and tune than the Tinker-Toy setup on a 4thGen.
InfinityShade
Aug 22, 2015 08:00 PM
sreZ28
Aug 14, 2015 07:48 PM
reiderz iroc
Aug 13, 2015 04:57 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
