Pitting at stabilizer bar pivot
Old Aug 25, 2023 | 10:02 AM
theraymondguy's Avatar
Fresh coat of tremclad satin on a newly sandblasted WS6 swaybar (‘91 Formula).
some pitting at the pivots, run it as is or sand to smooth?
it’ll get Moog stock replacement bushings
Old Aug 25, 2023 | 11:25 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: Pitting at stabilizer bar pivot
Run it as is.
Old Aug 25, 2023 | 01:46 PM
TransamGTA350's Avatar
Car: '89 GTA
Engine: ZZ6TPI
Agreed. Leave it.
Old Aug 25, 2023 | 05:32 PM
Yup; normal. Water inevitably gets into there, and it rusts. Even if you got a brand new one, within a few years it would be just like that, if driven in the rain. One winter if driven in salt.
Use the greasable bushings and send it.
IMO rubber bushings are inadequate in these cars. Too much force on the material. the rubber gets pounded out and leaves clearance in there, within only a few miles, and it "clunks". Poly, fit as tight as possible, with grease fittings, is MUCH better for those. Butt hay... we've all got to learn our lesson somehow.
Old Sep 8, 2023 | 12:02 PM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
There would be zero noticeable difference sanding them smooth.
Old Sep 8, 2023 | 12:53 PM
RedLeader289's Avatar
Car: 1983 Z28
Engine: 385 Fastburn
As-is. It's going to get rocks and grit thrown on it anyway.
ramblingarage
May 10, 2022 10:16 PM
Rellim88
Nov 23, 2019 11:11 AM
jorgeblancojr
May 2, 2016 08:45 PM
APACHE JOHN
Feb 6, 2013 10:21 AM
black84z28-4spd
Jun 16, 2005 04:11 PM
