Pro's and Con's of progressive rate springs
Old Jan 22, 2002 | 11:27 AM
z28onTweenkies's Avatar
Car: 1992 Camaro Z28 & 2k3 Cadillac CTS
Engine: LB9
Axle/Gears: 3:43
Im currently upgrading all of my suspension, and right now im doing spohn sfc's, kyb shocks and struts. Soon after, i will be looking to purchase some lowering springs. Ive heard that the progressive rate springs will make my car feel a little better over bumpy roads as opposed to some stiffer springs. Right now my car is quite noisy, hence the need to upgrade suspension. I would like something that would drop my car about 1.25" in the back and a little under 2" in the front. I will be going with some iroc 16" wheels in a few months (or if money provides some ROH snyper 17"s). My big question is, what is good about a progressive rate spring as opposed to a drop spindle or even a regular lowering spring? I always hear that the pro-kit from eibach feels better then the sportline, and that the intrax springs really lower a car but suck on handling. Like I said i would like something to increase my handling, but not totally sacrafice the feel. I hate feeling and especially hearing every bump in the road, thanks for any replies
Old Jan 22, 2002 | 07:16 PM
82camaro's Avatar
Car: 82 camaro SC
Sounds like you are stuck between a 'nice ride' and good handling. You can't have both. Everything you do to make your car handle better will make it ride harsher. Bigger wheels, drop springs, bigger sway bars will give you better handling, but it will ride rough. Progressive springs will give you a smoother ride, but will hurt cornering. You can't have both
Old Jan 22, 2002 | 09:37 PM
Engine: LB9
Axle/Gears: 3:43
hmm, but im not wrong by assuming that the eibach springs and the other things of the sort will be much better then stock right? i mean, they may not be the best in cornering, but i dont do any of that around town, and im sure they do a better job then the stock springs. maybe im wrong i have no clue
Old Jan 23, 2002 | 12:21 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
I have two words to say to that:
Cadillac STS
They corner awesome.
They Ride smooth.
but they have a computer system to adjust suspension stiffness and even brake the inside tires on hard turns. Thats when things start getting expensive...
F.I. 57 Belair
Aug 23, 2021 01:09 AM
87v6Bird
Jul 1, 2018 04:12 PM
86CamaroDan
Sep 29, 2015 10:08 PM
sandman92084
Sep 12, 2015 10:27 PM
scotrans am
Sep 5, 2015 04:26 AM
