2" drop spindle questions?
Old Jan 8, 2002 | 04:43 PM
LottaBallsCamaro's Avatar
Does anyone make a harder, stock length coil.
Wouldn't a drop spindle car handle better because of better suspension geometry?
Old Jan 16, 2002 | 10:25 PM
Bump
Old Jan 21, 2002 | 11:03 AM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
I believe that moroso sells springs of various stiffness. I don't know off hand what the stock ones are though. Someone posted a good setup, check the archives. I will probably just buy new stock springs.
A lowered car willl handle better because of its lower center of gravity. Drop springs mess up the suspension geometry. Drop spindles keep this geometry. Either way, you should buy LCA relocation brackets, adjustable panhard bar, and depending on how low you go, an adjustable torque arm. With these parts, you will keep the rearend geometry and prolong the life of the axle.
Old Jan 23, 2002 | 01:02 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Drop spindles do not change suspension angles, so they are a better way to lower a car, but lowering springs can actually have a positive effect on handling by making the tire 'lean' inboard a little. the bad thing is this eats through tires faster be making them wear on the inside edge.
Ghettobird52
Apr 21, 2020 08:44 PM
87iroctheo
Dec 4, 2016 11:47 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
