intrakz or eibach lowering springs ????
Old Jan 22, 2002 | 12:43 AM
88_RS&86_Z-28's Avatar
which one is better and lower the intrakz say they are a full 2 inches all the way around? but eibach say 1 3/4 to 2 1/4 ? anyone have either one and pics would help the best
Old Jan 22, 2002 | 02:53 AM
poorboy8's Avatar
Car: 79 Camaro RS
Engine: 355, carb, alum heads, XE262
Transmission: TH350
search dude!
Old Jan 22, 2002 | 04:14 AM
Jza's Avatar
Jza
What are you looking for? Just lowering, or better handling?
Old Jan 22, 2002 | 08:11 AM
both. but more just for lowering not to many places around here where i would need the performance of a lowered car
Old Jan 22, 2002 | 08:28 AM
LottaBallsCamaro's Avatar
You need to find out what the spring rate is on the springs...
I would recommend Eibach for handling and the intrax just for show.(this is just what I percieve)
Old Jan 22, 2002 | 02:05 PM
AntiVTEC's Avatar
I attatched a pic with my car lowered with eibach sportlines (at least i think i attatched the file properly!?!) I took out the rubber isolators on the springs both front and back. The front came down more about 1/8 of an inch because of the isolator and the rear about 1/2 inch more.
If you click the link on my sig, thats what my car looked like with the isolators still in there with the sportlines.
Old Jan 23, 2002 | 12:36 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
You took out the isolators? dude you kinda need those or the springs will sqeuak and sound like a$$
Old Jan 23, 2002 | 02:00 AM
RSpeed's Avatar
Car: 92 Z, 91 Formula, 04 CTS, 01 Tahoe
Engine: 355 forged 4 bolt, SuperRam, 58mm t
Transmission: T5, looking for t-56
I took mine off also,but I cut a piece of heater hose and slipped it over the first coil to keep it from squeaking and wearing out the pocket so quick.
My brother has an 89 RS with the Intrax.It is LOW. Looks good with the polished Iroc wheels he has. I have the Sportlines from Eibach. Ride seems close to the same in each car.Mine probably handles a little better though.
Bubbajones_ya
Jul 6, 2024 08:32 PM
Lanz06
Sep 14, 2015 07:16 PM
crzycamaro86
Sep 12, 2015 05:51 PM
Chiknhawk
Sep 10, 2015 08:55 AM
lakeffect2
Sep 7, 2015 03:52 PM
