Koni vs KYB
Old Feb 2, 2024 | 05:46 PM
wruiz's Avatar
Car: 1990 Iroc z-28
Engine: 350 TPI STOCK
Koni vs KYB
Hi all
I'll be installing MOOGs 5662/cc635. I understand these are NOT lowering springs, almost "factory". So my question is, is it worth spending big on konis or should I go the KYB route? If the konis work superior with "non-lowering" springs I don't mind spending my money on konis. Thanks in advance for any advice.
Old Feb 2, 2024 | 08:27 PM
Komet's Avatar
Car: 1989 IROC-Z
Engine: L98 350 TPI
Re: Koni vs KYB
You can spend far, far bigger than Konis. That being said, Konis are great shocks and you will likely enjoy them. KYB is the minimum acceptable choice.
Old Feb 2, 2024 | 09:23 PM
Reim's Avatar
Car: 1987 Camaro IROC
Transmission: 700R
Axle/Gears: G92 3.23
Re: Koni vs KYB
I put the Koni’s on mine and really like them. The shocks on my car were beat. With larger anti roll bars and the Koni’s it felt way better. I would say the Koni’s will be stiffer than the KYBs. The ride is still good with the Koni’s. I plan on keeping my car so I put the Koni’s on it. If you are going to drive a little spirited the Koni’s would be the choice. The KYBs would work for cruising.
Old Feb 3, 2024 | 02:41 PM
wruiz's Avatar
Car: 1990 Iroc z-28
Re: Koni vs KYB
Thanks for your reply. I might go with konis.
Old Feb 3, 2024 | 03:24 PM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
Re: Koni vs KYB
Konis are good whether the car is lowered or not. I have Koni front and KYB rear...
Old Feb 3, 2024 | 06:07 PM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
Re: Koni vs KYB
Even at stock height the Konis will provide a nice bump in handling. Especially over whatever old shock is on there now.
however lowering the car does provide some excellent benefits as well.
the shocks job is to control body movement. A crap shock will give you a crap ride and contribute to excessive body roll during transitions. A good shock will keep the car composed and far more comfortable to ride in.
Old Feb 3, 2024 | 08:08 PM
wruiz's Avatar
Car: 1990 Iroc z-28
Re: Koni vs KYB
Thanks all for your responses, I'm going for the konis.
DufussMan
Nov 2, 2011 09:22 AM
tf0r1
Sep 26, 2004 11:00 PM
drdave88
Jun 26, 2003 09:52 PM
Thirdgen86TA
May 16, 2003 09:31 AM
TKD89RS
Nov 16, 2001 09:23 AM
