Firebird Wheel Spacrs on the rear axle
Old Jul 7, 2025 | 11:08 AM
aycaramba's Avatar
Car: '1991 Pontiac Firebird
Engine: LH0 - V6 3.1
Transmission: TH700R4 automatic
Hello guys,
I have purchases spacers for my Pontiac V6 3.1 but they don't lie flat on the surface of the drum brakes (rear axle). I also checked my original 15 inch wheel, but they neither do even without the spacers inbetween.
Does anyone know of any good spacers that also fit on the rear axle with drum brakes? I drive the original 15 inch wheels on my Firebird.
The spacers I bought are with centering.
I have uploaded an image of the spacer mounted to the brakes, you cannot see but they are not flat enough on the drum.
Old Jul 7, 2025 | 03:45 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: Firebird Wheel Spacrs on the rear axle
There may be a lip that sticks up around the center hole of the drum. Remove spacer and see if the chamfer on spacer is to small.
Old Jul 8, 2025 | 01:58 AM
aycaramba's Avatar
Thank you for responding to my post.
I checked if there is a lip on the drum, because some of them had one. But there is no lip. Is there any space being made for the rear axles of the 3rd Gen? The spacer I bought is from Germany. It seems that the surface of them drum is not 100% even.
Do you also know if there is difference in the rear and fron rims of the Standard 15" wheel? Thank you!
Old Jul 8, 2025 | 08:46 AM
Airwolfe's Avatar
Car: 1992 Pontiac Firebird
Engine: 5.0L L03 TBI
The 15x7 wheels are the same front and rear unlike the 16x8 wheels which have specific front and rear wheels with different offsets due to clearance issues on the front of the car.
jamesv
Wheels and Tires
Apr 8, 2019 09:10 PM
1982firebird7
Wheels and Tires
Nov 28, 2015 02:07 PM
W72
Jul 13, 2006 08:21 PM
core997
Feb 6, 2003 11:33 PM
Markolc
Oct 18, 2001 09:18 AM
