Tricks fab 9b
Old Sep 15, 2025 | 05:11 AM
TMP85z28's Avatar
Car: 85 z28
Axle/Gears: Trick chassis Fab 9 3.89 locker
Tricks fab 9b
What's up guys new here,break down bought the car a couple years back. getting close to pulling the old 350 out. Here's a tricks chassis fab 9 with mostly umi suspension. The rear bolted on right in no -issue some suspension will b swapped out as my thoughts on the car has changed. Any questions or critics feel free as im learning a lot as I go but always trying to learn or help
Tricks fab 9
Tricks fab 9
Old Sep 15, 2025 | 07:43 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: Tricks fab 9b
I have a trick chassis 9" as well and the fit was really good. So much so that I didn't have to adjust pinion angle or LCA length. My only complaints, kinda noisy at speed. I knew this would likely be the case, which in of itself I don't care, but it always gives you that uneasy feeling of "is everything ok". The second is the drain plug. It doesn't have a shoulder or an internal stop so you could get into trouble if you were to thread it in too far and lose it inside. It also takes a thread sealer which mixes with the gear oil and has a slight slight leak. I just need to get a different plug I suppose.
Old Sep 16, 2025 | 04:43 AM
TMP85z28's Avatar
Car: 85 z28
Re: Tricks fab 9b
Seems to b a ongoing issue with the plug,gonna take it for a hit soon and see how she reacts. I had to adjust the pinion. But was from me Mounting coilover.
Old Sep 16, 2025 | 10:55 AM
bk2life's Avatar
Veteran: Army
Car: 91 WS6 GTA
Engine: 5.3
Transmission: 4l60e
Re: Tricks fab 9b
i gotta get one of these axles...
i dont want to go the 8.8 approach, as i have a few centers laying around with gears in them now.
Plus just saying you have a 9" sounds more impressive.
Old Sep 16, 2025 | 11:42 AM
TMP85z28's Avatar
Car: 85 z28
Re: Tricks fab 9b
beats the old 10 bolt that was in it tested it yesterday I need to make some minor adjustments. She hooked good but I did feel a little binding.adjustments on the coilovers and TA should have it all set.
Old Sep 16, 2025 | 12:52 PM
TMP85z28's Avatar
Car: 85 z28
Re: Tricks fab 9b
IROC-Turbo
Nov 10, 2022 06:26 PM
DrewRS
Mar 13, 2004 09:33 PM
LottaBallsCamaro
Nov 27, 2001 06:59 PM
SCCAjunkie
Apr 15, 2001 11:08 PM
