Thanks for posting. I have some clearance issues with my stock linkage and the LS7 dry sump oil pan. I wonder if this would help... unfortunately its been a little while since I looked at the problem so I'll have to dig into it.
Did they mention what ratio it is, or how much effort it takes to turn? Ratio and effort are kind of how these things (R&P racks) are described, and that info is missing from any of the info they have for the item.
Ratio is a fair question, but effort (or sensitivity) is variable depending on the flow rate of the pump from 2 gpm (more effort) to 3 gpm (more sensitive) which can be changed with different outlet fittings.
i didn't get a lot of info on it yet... they called me yesterday and i am customer number 1 for it... the fixtures, etc are just being finalized for production vs their shop car build... it is targeted to ship to me in mid january at this point... did confirm that it is basically bolt in, so if it performs it could be a great upgrade option potentially... figured worth the gamble on it to see if really have now a top of the line steering setup option for thirdgens outside of big mods like roadster shop offering, etc
Is this an electric assist steering or is there a pump that needs to be driven off the engine accessories??
I'd been looking at R&P but could only find units for aftermarket K-members. This bolt-in unit is nice. And its "Wonder Bar" design will tie the front frame rails together.
sent a request for all the tech stuff a week ago, no response yet from them. apparently will be into next year before they begin production, but they have a third gen mule with the parts on it so i hope they send something.....
I had a message typed up yesterday if you had any update... good timing. I'm not super happy with how my steering linkage works with the LS7 oil pan, I'm working around it interfering at full lock. It'll be interesting to see how this rack sits when installed.
Is the rack a specific casting for 3rd gens or an off the shelf part?
Can't wait to see it mounted .
i do not know for sure, but i would think they are using a rack that they already have and with the adaption being the mount and travel bar to have the correct location and travel... as you can see the inner tie rods supplied have a specific geometry, outer tie rods are standard OEM type
Hopefully its relatively easy to get parts for when the time comes to rebuild/replace.
Wonder how this would work with hawks new hub spindles.
Have you had a chance to install this yet? If so what's your opinion? Does it use the stock spindles? Is it worth the cost?
i have been working on a wiring harness for another project and haven't been able to install it yet... yes it does use the stock spindles. i am going to try and get it installed by early april so when nice driving season comes back to PA i can give a better evaulation... looking at it, it appears well designed and built
Rack and pinion steering would be a dream on these cars. The OEM steering system has so much slop that this would really liven it up. Definitely watching this thread with interest. I'd like to put it on my car but do not know if it would clear my headers. It would also be nice to find a way to install it without having to drill a hole in the k-member.
I would really like to drive a car with this back to back with one without to see the size of the difference to weigh the cost if it is worth it - personally worth it, everyone will have their own decision on that.
Super cool! I had no idea this was a thing until this thread.
My resto mod has a universal flaming river column that I think is really nice. Cleans up the dash area a lot.
I plan to use the new Hawks spindles, assuming there are no issues with them.
Always wanted to get a rack instead of all the stock linkages.
Good question. I have seen elaborate steering offset shafts with multiple pivots and brace bearings (other cars), but if it gets to that point the pros of of a rack may not be worth it.
Are the main benefits that it is a tighter steering feel over stock?
I always thought a rack would sort of "simplify" the front end but after skimming the instruction manual, it doesn't seem to really do that.
Still very interested though, feels like it pulls these older cars into the modern era a bit.
Nice looking modification. Is that a high temp ceramic coating that was taken off and added back after the mod?
Also, this car must have quite the altered front, is that an upper A-arm mount in that pic?
Yes, C4. You’re familiar with my build. It’s just been a minute. I had the headers ceramic coated before I found that the steering shaft hit them. I had to pay to have the left one coated a second time.
Reason: Add content
