Car Vibrates When Drifting
Car: 1988 Chevrolet Camaro
Engine: 2.8L V6
I have an 88 camaro with a manual transmission, I like to drift around corners or do burnouts but alot of the time when I drift the whole car shakes when I go sideways. I've read something saying rear suspension might be causing this, i've only been able to find one video that shows what im experiencing but it's on a toyota corolla:
If anyone can help me that would be great, it doesn't always do this and it's not as bad when its wet out but I know its not my tires because I've gone through 2 sets of tires and nothing has changed.
Car: 91 WS6 GTA
Engine: 5.3
Transmission: 4l60e
Re: Car Vibrates When Drifting
wheels
driveline
pinion angle
unbalanced engine
No one can point to what the issue is, you need to become the detective and figure it out.
easiest is put on different rear wheel/tires on and see if it changes
from there, everything will be trial and error until you find it
driveline
pinion angle
unbalanced engine
Engine: 2.8L V6
wheels
driveline
pinion angle
unbalanced engine
driveline
pinion angle
unbalanced engine
Any bad bushing can cause this besides all the other possibilities. It is caused by an oscillation. Basically your tires are loosing grip and immediately gain grip again then repeating the process. Have a friend wiggle the rear body of the car back and forth while you lay underneath watching every mount and bushing. Something is loose. It might be all just wore enough to contribute.
Also check for a bent wheel or axle.
Car: 91 WS6 GTA
Engine: 5.3
Transmission: 4l60e
Car: 82 TA
Transmission: Magnum f
Axle/Gears: Ford 9 w 4.11
I had issues like this when i started to dial in my suspension. I had full poly bushings and solid trailing arms w relocation brackets/panhard bar/torque arm. I replaced my trailing arms w adjustable ones w roto/heim joints and adjusted my pinion angle and now it rips. My issue was a mix of poor pinion angle and binding w poly joints. The roto/heims are much better. If you have an original suspension then something is loose/bad bushings or both. Sticky tires will exaggerate this.
Engine: LT1, L400
Transmission: ZF6, T5
Axle/Gears: 3.45, 3.31
Transmission: Pro-built 700R4
Aside from new rear tires, we know nothing of your suspension setup. Some information about what you have on your car would be very helpful.
FiReBReTHa
Apr 1, 2002 12:03 PM
