Compressing rear brake piston...HELP!!!
Old Jan 26, 2002 | 12:21 PM
Abubaca's Avatar
OK- Someone posted a question about this the other day, and I thought all my problems were solved...but they're not.
I got the "tool" that is supposed to rotate the piston. I went to change the brakes today and I find that the piston only has a hex wrench fitting, nothing close to the square-ish fitting I expected that would've fit the "tool" I bought. I do have an 89 that has the PBR rear caliper, does that explain my dilemma? And if so, what do I do now? I realize that I can remove the Ebrake mechanism and do it that way, but twice now I have been defeated, and I must conquer GM/haynes manual( ) by doing this correctly, not by bypassing the problem...
...please help!!!
Old Jan 26, 2002 | 01:15 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Are your calipers aluminum or iron?
If they're aluminum, then they're the PBRs. AFAIK they can be compressed with a C-clamp just like the fronts. At least, my PBRs can.
Old Jan 26, 2002 | 06:44 PM
Abubaca's Avatar
All 89's and up that had rear discs had PBR's. It might've switched in 88 but I think was 89....ANYWAY, mine are stamped with PBR, so I'm guessing that at least MY 89 has PBR's.
I can't compress the caliper cuz the e-brake pin is in the way. I keep reading that you need to rotate the piston, and that makes sense, but HOW? The "tool" everyone keeps mentioning had no where to go. The piston should have a fitting , at least to my understanding, but I only havve a hex key whole in the center of the piston. Someone's got oknow what I'm talking about!!!
Old Jan 26, 2002 | 11:29 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You don't need the tool for 89+ brakes, just a C-clamp.
Old Jan 27, 2002 | 12:32 AM
Abubaca's Avatar
Ok, I'll try this AGAIN I CAN"T COMPRESS THE PISTON BECAUSE OF THE E- BRAKE PIN/MECHANISM. THE BIGGEST C CLAMP IN THE WORLD IS NOT GONNA HELP, UNTIL I MOVE EITHER THE PIN OR THE PISTON.
If I took the car to GM, what would THEY do?
Old Jan 28, 2002 | 11:32 AM
BlackBird91's Avatar
I have a 91 TA and had no problems compressing the piston.
Just make sure the bleeder is open.
Old Jan 28, 2002 | 11:43 AM
Abubaca's Avatar
I'm glad no one else has this problem.
Nevermind,...I'll call GM.
Old Jan 28, 2002 | 07:48 PM
TVP's Avatar
TVP
here's a way to NEVER EVER do it ...
stick a screwdriver inbetween the pad and rotor ..
you'll DISTROY the pads ... gouge the rotor's
if you really try .. but you'll know right away if you
can compress it easily ... if you want to rotate the
piston back in ..grab it with vise grips ... these are the
methods your local ASE cerified $39 per axle shop
will use ....
TVP
Vintageracer
Jan 10, 2020 05:33 PM
Eric-86sc
Apr 3, 2016 03:52 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
kyleb24
Aug 15, 2015 08:24 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
