front end creaking
Old Jan 29, 2002 | 01:05 AM
mudaholic's Avatar
front end creaking
my front end creaks really bad.. almost sounds like its grinding actually.. the only time i notice it is when im doing low-speed turning, i believe.. havnt heard it any other time than that.. the guy i bought it from said the sway bar might need to be tightened.. could that be the problem? or anyone have any other suggestions? thanks in advance!
Old Jan 30, 2002 | 02:37 AM
Joel Geerling's Avatar
Car: 91 Formula
Engine: 305 TBI
What you're describing sounds like a common problem with 3rdgens. Does it generally only occur in a tight low-speed turn (like when parking)? I fixed the same problem with two shots of the grease gun. Check out my post in this thread: https://www.thirdgen.org/techbb2/sho...teering+crunch
Hope that helps
Old Jan 30, 2002 | 05:04 AM
ANDYZ28's Avatar
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
Sounds to me like it could also be cracks in the frame at the steering box mounting location. Another common 3rdgen problem.
THanx,ANDYZ28
Old Jan 30, 2002 | 07:28 PM
gmanuel's Avatar
Could also be the bearings at the top of the stud tower.
Old Jan 30, 2002 | 08:31 PM
mudaholic's Avatar
thanks a bunch folks! ill be sure to check these areas out when i get home this weekend.. thanks again for the info!
customblackbird
Aug 15, 2021 10:16 PM
Terrell351
Jun 13, 2021 01:13 PM
Amillionoh7
May 24, 2020 08:01 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
bellez77
Sep 5, 2015 08:39 PM
