Pulling The Front Wheels
Old Jan 29, 2002 | 03:44 PM
Z28SpeedKing's Avatar
I was wondering if anyone in here has ever pulled the front tires off the ground in thier third gen. If so what they did to the car to make it ot it:lala:
Old Jan 29, 2002 | 04:34 PM
Tas's Avatar
Tas
jack stand :lala:
Old Jan 29, 2002 | 10:55 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I should be doing it this season after the changes I've done to the car.
How to do it?
Lighten the front end. Third gens are very nose heavy. Deep gear ratio of at least 4.10. 4.56 is better as it mutiplies torque more. Slicks are a necessity. The engine should be producing a lot of torque or the front end should be a lot lighter than the rear.
Finally to yank the front wheels off the ground you either need a manual transmission to do a high rpm clutch drop or a automatic tranny with a transbrake. Both of these will require a driveline that can handle the shock.
You could also throw a couple of engine blocks into the rear of the car to make it back heavy. That should do it also.
Old Feb 1, 2002 | 06:31 PM
rhuarc30's Avatar
To yank the front wheels you need three basic things. A stiff chassis, otherwise the chassis flex will absorb the lifting force. A lot of power, obviously. And hella hook-up or you'll just spin the tires. However you don't really need a transbrake, though it does help. Also anything that helps weight transfer, like lightening the front end, battery relocation, 90/10 shocks, front drag springs, all that stuff. And a better torque converter/higher stall speed converter.
John
B_Dubya
Aug 26, 2015 05:09 PM
kah992
Aug 19, 2015 02:55 PM
wruiz
Aug 11, 2015 02:59 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
johanlindgren
Wheels and Tires
Aug 6, 2015 03:32 PM
