HELP or $550
Car: 1990 Trans Am
Engine: Lb9
Transmission: factory T5
Axle/Gears: 3.08 limited slip
HELP or $550
man im pissed, i went to go get alignment done and they couldnt do it because i need new centerlink, idler arm, and lower ball joint and was quoted at $540 parts and labor at midas. Has anyone had it done cheaper and where or how hard to do myself?
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Depending on your confidence level, you could just replace that stuff yourself. None of it takes great skill but, if you don't have stuff like a good jack it would be more difficult. The centerlink & idle arm can be replaced w/o getting the car off the ground but, it does make doing that more difficult.
Autozone prices...
$33 idle arm
$46 centerlink
$13 ball joint
$100 to rent a ball joint press ($ gets refunded upon return of tool)
$20 (or so) to rent a ball joint seperator ('pickle fork')
$92 for parts & a temp loss of $120 for extra tool. Doing it yourself & saving the cash is always well worth it (IMO) plus, for an extra $13 you could do the opposite side ball joint & not have to worry about it crapping out shortly after your new alignment.
It took me a little over an hour when I did them on my camaro (1st time using bjoint press tool) and wasn't nearly as hard as I had imagined (comparing it to when I rebuilt the front of my 'bird with a homemade press).
Other than doing it yourself you're going to pretty much be stuck close to that price. Most places (that I've run across) like to charge a little extra for 'their' parts as well. I was quoted around $500 for new outer tie rods, an idle arm, & a ball joint to be put on from pepboys and a little over that from a local alignment shop. Being the po **** I am, I opted for the DIY option. Fortunatly I had my friends garage to borrow at the time (my 'bird was a bit more..spread out then..)
Autozone prices...
$33 idle arm
$46 centerlink
$13 ball joint
Wow, you paid $20 to rent a pickle fork? You coulda bought one for about 7 bucks. It's gonna be an admittedly cheap one, but if you're just doing it for one or two jobs in your lifetime, it's good enough.
Engine: TPI 305/ v6
I personally own a $10 and have gotten lots of use out of it (beyond just seperating ball joints).
$20 to 'rent' one isn't bad considering you get every dollar back when you take it back to Autozone so really, you're not paying anything (unless you lose it)
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
88SS6SPEED
Nov 11, 2015 07:05 AM
the_hamturdler
Sep 30, 2015 12:50 PM
