Spring Replacement
Old Feb 6, 2002 | 10:20 AM
camaro6spd's Avatar
Spring Replacement
What are a good set of replacemnt springs, seeing that the car has 130,000 on it, i am afraid that the springs are worn out. I would like to lower the car, but I had a 2" lowering kit on the black car it is was just too hard to drive around here. I would like to retain stock ride height, maybe a little less.
Old Feb 6, 2002 | 10:32 AM
Js92RS's Avatar
Car: '92 Camaro RS
Engine: 355 TPI
Transmission: Tremec T-56
Axle/Gears: 10 bolt/3.42
If you want the stock height, I would suggest getting the Moog springs, but if you want your car lower then I would suggest the Eibach springs which lowers your car 1 to 1 1/2 inches.
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
gta90
Sep 15, 2015 04:00 PM
TheExaminer
Aug 25, 2015 07:34 PM
