air lift bags?????
Old Feb 8, 2002 | 08:38 PM
88_RS&86_Z-28's Avatar
air lift bags?????
I have heard this are one thing i should do to get traction at the track. i was just wondering where you guys put the valve to fill them with air i was think behide the LP so its easy to get to and its still hiden. and how much air should be in them?
Old Feb 9, 2002 | 12:49 AM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Yeah could you use these to lower a car? With some light springs. I'd like to be able to slam it and raise it by blowing the springs up.
Old Feb 9, 2002 | 01:19 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Each car is different so the air pressures will vary from car to car. I usually have 5 psi in the driver side and 15 psi in the passenger side.
The idea is to increase the pressure in the passenger side to prevent that side of the diff from raising under hard acceleration. That's why when a battery is relocated to the trunk, it's mounted on that side to add weight.
When properly adjusted, air bags can even make an open diff car hook up like a posi.
These air bags will not work to "slam" the car down. The third gen's suspension just isn't designed properly. The diff is already too high up in the body.
Run 2 seperate lines for each air bag. Locations are up to you. I have mine mounted under the rear bumper and find it impractical to check the air pressure. I also have overload air bags on my truck with a single line and I mounted the filler inside the gas cap door.
Old Feb 9, 2002 | 01:58 AM
Jza's Avatar
Jza
And besides, that's not what those are designed for. The air bags they use for "slamming" a car (the good ones, anyway) are a lot more heavy duty and cost somewhere in the $1200 range for a full set.
Pressure recommendations will be included in the instructions.
Old Feb 9, 2002 | 03:15 AM
i dont want them to slam my car down if i wanted to that then i would just buy the springs. i just heard that they are good for the traction and trust me thats all i want them for or should i say need them for are they that hard to install or fairly simple since they wont have air in them when i install them.
:hail: :lala:
Old Feb 9, 2002 | 12:19 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
I don't really want to slam it, i just want to use very loose springs and the bags so the first inch of travel is easy and then the suspension would become really stiff.
Old Feb 9, 2002 | 02:32 PM
ede's Avatar
ede
i ran seperate lines for mine. put the valve i nthe rear sump with a gauge on each line. not very well hidden, but very easy to get to and to read the gauges.
1992 Trans Am
May 10, 2023 07:19 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
dennisbernal91z
Wheels and Tires
Sep 6, 2015 11:12 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
