Big Problem with Installing Spohn Torque Arm
Old Feb 10, 2002 | 10:53 AM
CamaroX84's Avatar
Ok, got the torque arm and cross member in okay, but the problem comes with the grease fittings on both pieces. The fitting on on the cross member was not installed on straight. It is not flush against the metal. It is fine on the torque arm though. When it's all bolted up, the fitting on the cross member touches the torque arm, meaning the slightest bend and it will snap off the fitting for sure. Anyone have any suggestions on what to do? I'll post some pics later. Any help would be greatly appreciated. Thanks.
Old Feb 10, 2002 | 12:24 PM
SteveSpohn's Avatar
I think I know what you're asking, but not 100% sure. If you mean the poly end on the front of the arm, you can just give it a half a turn and the fitting will be on the top.
Steve
Old Feb 10, 2002 | 05:23 PM
89formula#1's Avatar
Car: 89 Formula
Engine: Carbed 5.7
Transmission: TKO-600
hey steve i am looking to get the best traction possible from my 89 firebird formula with a 9-bolt disc rear. what do u recomend buying and what is the adavantage of your stuff over hotchkis. thanks
Old Feb 11, 2002 | 02:40 PM
CamaroX84's Avatar
Steve, here is what I am talking about. Thanks.
http://www.geocities.com/camarox84/Dsc00020.jpg
http://www.geocities.com/camarox84/Dsc00021.jpg
For some reason the links won't work, so you have to copy and paste the url to see it.
Old Feb 11, 2002 | 05:01 PM
SteveSpohn's Avatar
Okay, I thought that's what you were asking. Every car is different, slightly, the plates should be close to straight up and down, yours are leaning back a bit and that's why the fittings are close. I have started putting the bushing fitting out the front now to eliminate that. All you need to do is loosen the jam nut for the front poly bushing and turn the bushing out a few turns. That will lengthen the arm a bit and give you enough clearance on the fittings.
Steve
Frozer!!!
Jan 19, 2024 04:55 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
IROCZ1989
Jan 24, 2016 03:55 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
