Stock Suspension, whats first?
Old Feb 12, 2002 | 12:48 AM
92RS shearn's Avatar
Car: 92' RS
Engine: LO3
Transmission: Probuilt 700R4
Axle/Gears: 3.70 9-bolt
I have plans underway this spring, to give my car some much needed power. LT1 cam, heads, intake, 3.42 posi rear,shift kit.
Now I need a suspension to back it up, like I said its stock. I have a strut tower brace on its way, but thats it.
Old Feb 12, 2002 | 01:30 AM
vjo90RS8's Avatar
Car: 2002 Z28
im planning on doing the same thing, im gonna focus on my suspension for the next 6 months, then it is on to the rear end.
Here is my total suspension plan, nothing super fancy, im not trying to build a drag car.
Spohn Sub Frame Connectors ($155)
Edelbrock Strut Tower Brace ($130)
Spohn Lower Control Arms (adjustable-poly), Panhard Bar(same), Relocation Brackets ($320)
Hotchkis Performance Springs ($220)
Koni Gas-a-just Shocks, GR-2 Struts ($160)
PST Front end rebuilt kit and parts ($300)
and possibly IROC front and rear swap bars and wonderbar ($100)
Total off........$1385
that is the plan, SFCs and STB going on this weekend, finally i get a break from school, so that is $285 down, $1100 to go
So hopefully this will be a pretty nice setup
Old Feb 12, 2002 | 01:47 AM
vjo90RS8's Avatar
Car: 2002 Z28
ok, i just reread your post, SFCs are a must, they should be first, then since your are going with 3.42 gears, LT1 cam, etc. go with the lower control arms and relocation brackets. Those should help your traction. If your planning on doing the LT1 cam swap this spring, i say just do those suspension mods along with your STB first, then do the rest later when you have time.
I just resently bought an LT1 cam, but im dont think it will go on until the summer. Tryin to knock the suspension and rear end stuff out first so i dont have to worry about them for a while.
Old Feb 13, 2002 | 11:11 PM
GoldenSwordZ28's Avatar
Just wanted to point out that those Shocks and Sturts are NOT Konis, there KYB's. I just got mine into my Z28, them things are great (Though I don't race or anything).
Old Feb 14, 2002 | 12:01 AM
vjo90RS8's Avatar
Car: 2002 Z28
oops, thats what i meant, KYBs, i guess i just subconscously wish i could afford some Konis.
Old Feb 14, 2002 | 12:12 AM
turningfast's Avatar
First of all, do a front end kit, bushings, ball joints, center link, and everything else. Then the rear contol arms, a boxed style, as well as a panhard rod. What's the point of trying to improve the rest of the car when the (probably) most worn and neglected part of your car is sloppy
customblackbird
Aug 15, 2021 10:16 PM
LT1Formula
Nov 16, 2015 01:13 PM
Genopsyde
Oct 7, 2015 08:35 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
TheExaminer
Aug 25, 2015 07:34 PM
