Relocating panhard rod
Old Feb 17, 2002 | 04:12 PM
5 litre eater's Avatar
Car: '84 Trans Am
Engine: 350ci Sportsman heads, B&M blower
Transmission: Turbo 350
I need to drop my panhard rod about 2 inches on the passenger side to make room for dual exhaust. The guy whos doing it says he can make a bracket to lower enough to clear the pipes, but I was wondering if it would mess up my suspension or anything by relocating it.Any help would be great. Thanx
Old Feb 17, 2002 | 04:21 PM
PF Flyer's Avatar
Car: 87 T/A
Engine: TPI 350 ci
Transmission: 5 speed
... so long as it locates your differential in the right spot and keeps it there while cornering, doesn't bottom out and has enough lateral movement it should be OK.
Old Feb 17, 2002 | 05:28 PM
CODY BEHNKE's Avatar
Don't move stuff like that for an exhaust, If you decide to do that though make sure it's on good.
Old Feb 21, 2002 | 09:39 AM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
If you just drop it straight down, mkae sure you replace the panhard rod with an adjustable version. To reuse the stock one, the bracket would need not be straight down but on an arc.
Old Feb 21, 2002 | 12:20 PM
Car: '84 Trans Am
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
darwinprice
17
Oct 11, 2015 11:51 PM
LT1Formula
Oct 8, 2015 08:34 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
