tires making an uneven tread noise.....please help!
Old Feb 19, 2002 | 09:25 PM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
Transmission: TH-700R4
Axle/Gears: GM Axles and GM 3.73
my ball joints have been bad for a while and i finally got them fixed and now my tires are making a rubbing noise and it seems to b getting louder and louder cuz i dont remeber it being this bad b4.......the guy aligned my car so could it b that i need a new tire or do you think the guy screwed up on aligning it?
please help.....im tired of the stupid noise
Old Feb 20, 2002 | 07:29 AM
82camaro's Avatar
Car: 82 camaro SC
When the ball-joints were bad and the alignment was off, the tires were probably damaged. New ball-joints and an alignment won't fix the damaged tire or tires. Once a tire starts to 'chop', it will get worse regardless of alignment. Also, you might check other stuff. Like the bearings, make sure nothing is rubbing on the tires, make sure nothing is rubbing on the brake rotor,....
Old Feb 20, 2002 | 10:13 PM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
well could my tire b damaged without looking like it is......cuz my tread doesnt have any bald spots on it.....it looks just like the other tire........and i just took out the wheel bearings last fall when i got the rotors turned and they were fine....and i greased them up really good!!......im pretty sure that nothing is rubbing the tire or rotor
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
fonzie85
Exterior Parts for Sale
39
Mar 16, 2016 07:07 AM
demontransam89
Wheels and Tires
Dec 28, 2015 06:58 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Fronzizzle
Aug 9, 2015 01:15 PM
