rollcage install need help!!!please
Old Feb 19, 2002 | 09:32 PM
jester111's Avatar
Good day people
I have posted before but I did not get the response I was looking for and I have also gotted alot of other contradicting ideas.
I have a 10 point rollcage built by comp. engineering and I must say this is one of the best cages for the money I have seen.
What is the prefered and best way to raise and level the car to insure there will be no slop, bow, or twist in the chassis? Does it matter if the suspension is loaded or drivetrain installed? I have my car literaly ripped apart with nothing left on it, I cant load the suspension if nessesary.
Thanks in advance for any much needed advice
Old Feb 20, 2002 | 04:45 AM
ede's Avatar
ede
since you can't move you car, find one just like it. then park it on a know level surface and take some measurements with a angle finder. now go to your car and replicate the measurements, use shims under jack stands or what ever works. that should be enough to get the roll cage in correctly.
Old Feb 21, 2002 | 02:48 PM
bradkeith's Avatar
Jester, make sure you post back and let us know how the install went..maybe some pics? I've been considering buying a comp. engineering 8pt roll-cage, But i don't really need it quite yet, maybe after i get my motor-swap done
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Apr 25, 2017 07:14 AM
dennisbernal91z
Fabrication
29
Mar 2, 2017 12:04 PM
gixxer92
Sep 1, 2015 04:32 PM
silentkillzr
Mid-West Region
Aug 16, 2015 09:22 AM
