getting the shocks off??!!??
Old Feb 27, 2002 | 03:14 PM
BG87z's Avatar
Car: 1987 IROC-Z
Engine: Carbed 355
Transmission: TH-350
Well i posted this a while ago but ill try again. now i am still trying to get the rear shocks off. when i try to turn the nut on the top of the shock, the rest of the shock just moves. ive tried vice grips but they shock just slides throught them. i am very close to getting out the cutting torch so can someone help me. thanks a lot
Old Feb 27, 2002 | 05:41 PM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
Re: getting the shocks off??!!??
hold the dust cover on the shock. other than that, if you can get a grinder where you were using the vise grips at. then grind the rod to the point where you have two flat ends. then put the vise grips on it to hold it. or just take the grinder and cut through the rod. and if all else fails, use the torch.
Old Feb 27, 2002 | 10:29 PM
86FyrBrd's Avatar
Car: 1992 Camaro Z28 Convertible Z03
Engine: 383 SuperRam
Dont worry if worst comes to worst just realize your not alone, my friend is taking my car to work tomarrow to grind, or torch his way through the top bolt for my drivers side strut. Man that thing is a Bi***
Old Feb 27, 2002 | 11:44 PM
turningfast's Avatar
Impact gun should do it well. It will spin the nut faster than the shaft of the shock will turn
Old Feb 28, 2002 | 03:31 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
You guys see that little thing that snaps off the upper part of the shock's stud? That would work great...
Or you could buy a nut splitter. Don't torch thru the car to the gas tank!
Old Feb 28, 2002 | 10:33 PM
86FyrBrd's Avatar
mine are all done now...but I was talkin about the front struts not rear shocks :-)
darwinprice
17
Oct 11, 2015 11:51 PM
LT1Formula
Oct 8, 2015 08:34 PM
loud91rs
Oct 5, 2015 10:05 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
meeklay812
Oct 1, 2015 03:46 PM
