Manual Steering Box
Manual Steering Box
I would like to convert my F Body to a manual steering setup. Does anyone know of a steering box that will bolt up to the third gen F Body. I can't locate a manual steering Bird or Camaro in the local bone yards, so I thought I'd see if anyone knew of anything that will work.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Look for an S10 or S15 with a 4 cyl engine. They usually have manual boxes and they bolt right in.
Thanks for the info, Stephen! Does the F Body Pittman Arm (or is it the idler arm???) need to be changed to that of the S Trucks also, or can I retain the F Body's.
I really appreciate the info! :hail:
Car: 87 IROC L98
The S truck's pitman arm has a slightly different angle. You can use it if you have to but I'd suggest using the f-body's pitman arm.
1992 Trans Am
May 10, 2023 07:19 PM
backtothe80s
Sep 5, 2015 12:39 AM
