Loose struts???
Old Feb 28, 2002 | 04:53 PM
Slow89Iroc-Z's Avatar
Car: 1989 Iroc-Z
Engine: 350ci SBC
Loose struts???
I have an 89' Iroc-Z with an L98 and hardtop. The front end makes a popping and grinding noise when I go over bumps and turn the wheel. So I replaced the idler arm and center link and it didnt help, put new end links on and it didnt help.... So one day I pull the tire off and grab the strut at the top and I could wiggle it back and forth like an 1/8 of an inch......So I think I found the problem but do I only need to replace the struts or both the struts and strut mounts on the towers? If I grab it on the botom where it is bolted I cant wiggle it much at all so I think the ball joints are good. The car has 60K miles on it and it is well kept. Apparently the previous owner had the struts replaced because there are Monroe Sensatrac struts and shocks on it now.. Are these good? I am looking for a stock ride quality so should I go for another set of Monroes or Gabriels?? How are the Gabriels...do they compare to monroes in quality and performance? I cant afford paying over $150 a strut......whats a good strut that will give stock ride quality and last a while????
Old Mar 1, 2002 | 07:46 PM
nicmike85's Avatar
You need to replace the bearing plates.
Ed1LE
Sep 30, 2018 09:14 AM
LT1Formula
Oct 8, 2015 08:34 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
tcflint
Sep 27, 2015 05:58 PM
