NO BRAKES!! when engine is running..??
Old Mar 5, 2002 | 06:32 PM
350turbo411's Avatar
Car: 1983 Z28 Clone
Transmission: TH350
hey guys... the car is not on the road but......when the car is not running ..the pedal is hard..when i start the car.. the pedal goes to the floor ..and i hear a hissing sound.......actually like a swooshing sound.... any ideas ????
Rob
Old Mar 5, 2002 | 06:36 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Your power brake booster is fornicated.
The reason is that your master cylinder got fornicated first, and leaked fluid out its seal, which got onto the diaphragm in the booster and ruined it.
Old Mar 5, 2002 | 06:58 PM
Car: 1983 Z28 Clone
Transmission: TH350
by saying fornincated you mean ..like flooded ????
so i need a new master cylinder and a power booster..???
costly
Old Mar 5, 2002 | 11:51 PM
Pro91's Avatar
brakes
did you check to see if the vacuum line to the master cyl. is hooked up.... it runs from the manifold to the booster
good luck
Old Mar 6, 2002 | 12:32 AM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: Pro-Built Automatic/Vigilante 2800
No, if it were a vacum leak the pedal would be stiffer with the engine running due to lack of boost.
Old Mar 6, 2002 | 01:02 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
They're about $100 for the set, in fact, most of the time the only way you can even buy a booster is with a new MC attached, because about 90% of the time when the booster goes bad it's because a leaky MC sodomized it.
Old Mar 6, 2002 | 01:14 PM
Car: 1983 Z28 Clone
Transmission: TH350
thanx guys.. yeah the vac line is fine....
Rob
Old Mar 6, 2002 | 01:52 PM
Car: 1983 Z28 Clone
Transmission: TH350
Just got off the phone with my machanic... he says its not the booster......and that i'm loosing pressure somewhere..???? where could i be loosing pressure???????theres no leaks.....
Old Mar 6, 2002 | 03:59 PM
87ROCZ's Avatar
Car: 1987 Camaro IROC-Z
Engine: L98 bored .40 (357 ci)
Transmission: Race Ready 700R4
Axle/Gears: 9 bolt 3.70 posi
costly
I think when he says "fornicated" I think he means its "fu@ked" .. ... or am I wrong here?? hehehe...
Old Mar 6, 2002 | 08:01 PM
Car: 1983 Z28 Clone
Transmission: TH350
hahah.. i seriously have no idea what that means.............
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
