what is difference between these Eibach springs??
Old Mar 6, 2002 | 08:19 PM
breathment's Avatar
the Pro-Kit and the Sportline.. I know the Sportline are lower, about 1.7" front and 1.4" rear.. Would this be a good drop??? what are the other differences?
Old Mar 7, 2002 | 12:38 PM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: Pro-Built Automatic/Vigilante 2800
I don't think there are any real diffrences between the two besides the fact that one lowers the car more than the other. The only difference I can guess would be maybe a slight improvement in performance with a lower center of gravity. 3gens look good with either set installed, but I prefer the lower of the two with a larger aftermarket wheel, just looks better to me than going that low with the stock wheels. But it's all about what you want.
Old Mar 9, 2002 | 08:05 PM
TP355Z's Avatar
Car: 1988 Camaro SC
Engine: LT1 SBC
Transmission: LT1 T56
Axle/Gears: 3.73 Moser 12 Bolt
hey - i've got the sport-line kit i think (the lower drop) - in fact, your post informed me of that! The springs were installed b4 i bought the car (upside down w/o spacers - i was real happy 2 learn that) but there is a noticeable rake in the front end w/the lower kit. If you want a level ride (which i do/did) get the pro-kit. Its all good tho - make sure 2 check clearance. My wheel-wells are rubbed a little b/c i guess the car had big wheels b4 i bought it. Its got 16X8 IROC rims now
Hope this helps
Old Mar 9, 2002 | 09:24 PM
racereno's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: Stock
And remember to keep in mind tire diameter is going to make a big difference in what works for you.
Old Mar 10, 2002 | 02:30 AM
360Iroc's Avatar
well i need to correct something for the above stated i have bought many eiabach spring kits and the sportlines are the lower of the two kits, the pro-kit give you a little better ride and less drop...they are design for someone looking for performance handling and no real drop...the sportlines are awesome though and i would recommend these to anyone
customblackbird
Aug 15, 2021 10:16 PM
NORTz89
May 20, 2020 03:51 PM
deracer
Apr 11, 2016 12:04 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
86White_T/A305
Aug 17, 2015 12:16 AM
