alignment gurus, sai angle ?
Old Mar 11, 2002 | 11:09 PM
jester111's Avatar
hey guys
I was doing some reading but this text is limited to the info.
If camber is the tilt of the wheel,and the sai angle is also refered to the tilt of the wheel then how can the same angle be measured twice or have the measurment? A explination would be great if possible please.
Thanks in advance!
Old Mar 12, 2002 | 07:51 AM
Norm Peterson's Avatar
Car: '08 Mustang GT
Engine: 4.6L
Transmission: º º 0 . . . |-|-|
Axle/Gears: 8.8", 3.55
SAI and camber are related items, but they aren't different names for the same angle.
SAI is the angle between an imaginary line drawn through the balljoint and the upper strut mount (definitely NOT a vertical line) and the plane of the wheel as viewed from the front of the car.
Camber is the angle you measure between the plane of the wheel and the vertical.
Norm
Old Mar 12, 2002 | 08:40 PM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
Norm
IA (included angle) is what you just described. it is SAI and camber combined.
SAI ( steering axis inclination) is line drawn through the strut mount and ball joint to the vertical line which is zero degrees. this is useful to determine a bent strut in our case.
camber you are correct on.
Old Mar 14, 2002 | 12:09 PM
Car: '08 Mustang GT
Engine: 4.6L
Originally posted by mrr23
. . . SAI ( steering axis inclination) is line drawn through the strut mount and ball joint to the vertical line which is zero degrees . . .
I stand corrected (thanks, ). FWIW, I find it a bit scary that the only place in my collection of reference books that clearly shows that SAI is referenced to the vertical is Mathis' Mustang Performance Handbook 2.
Norm
Ed1LE
Sep 30, 2018 09:14 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
meeklay812
Oct 1, 2015 03:46 PM
mfp189
Sep 27, 2015 09:25 AM
89 formula TPI
Sep 20, 2015 10:54 AM
