loud pop
Old Mar 13, 2002 | 01:00 AM
91blkta's Avatar
Car: 1991 Pontiac ta 5.0l 2005 pontiac gxp 5.3l ls4 dod 2003 GMC Envoy 4.2l
loud pop
When I turn hard to left or right the front susp pops very loud. Something in the front is worn have any of you had the same problems with yours If so what was causing this
Old Mar 13, 2002 | 02:17 AM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
I think I am having the same thing. I just made a post about it called "clicking."
Old Mar 14, 2002 | 06:08 AM
Administrator
When I make sharper turns I get a click like sound from either lefts or rights, is this what u have too??
Old Mar 14, 2002 | 11:30 AM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: Pro-Built Automatic/Vigilante 2800
I had the same problem. Turned out to be the wheel stops. Just put some type of lube on there, something that sticks good. I used some left over ES lube I had, and problem was gone. Rub some on the stop itself and some on the spindle where it makes contact.
On mine it would only happen when I turned one way the other was fine. When I got under there I could see that the side where it would pop there was no lube, the other still had some. But I went ahead and did them both and haven't heard it since.
Old Mar 14, 2002 | 12:04 PM
Steve89GTA's Avatar
Don't overlook the possibility of a cracked frame near the steering column. Popular problem.
Old Mar 31, 2002 | 02:14 PM
astro808's Avatar
My 91 Z has some noise also. Found out steering box mounting area had a crack in it
RS Reaper
Oct 17, 2018 07:52 PM
loud91rs
Oct 5, 2015 10:05 PM
Luigytico09
Oct 1, 2015 08:46 AM
aaron7
Sep 30, 2015 09:15 AM
Lmancha96
Sep 25, 2015 08:11 PM
