I think I may have a stuck caliper piston, also a noise I think related to brake pads
Old Mar 14, 2002 | 12:15 PM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: Pro-Built Automatic/Vigilante 2800
The other day I had the front end on stands. I spun the driver side and it spun somewhat freely with a little resistence from the pads. I spun the passenger side next and it spun freely and kept spining, the pads were not touching at all. I thought that the pads were suppose to rub against the rotor a little bit even when the brakes are not applied? I don't experience any pull but it just didn't seem right.
Also I have the single piston caliper type, I've been hearing a clicking noise from the driver side everytime I brake. It's not a continuous clicking while braking it will just make it when I first begin to apply the brakes. I'm thinking maybe it's one of the pads sliding forward when I brake and taping against the caliper. I have removed the pads from the caliper once before and when I reinstalled them I didn't think about those 2 tabs on the outter pad that your suppose to bend up against the caliper. Could this be the reason it makes the clicking noise when I brake, because the tabs are not pressed firmly against the caliper?
Old Mar 14, 2002 | 01:53 PM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Well never mind about the noise I just checked it out and it's the strut mount. Wiggled the strut and could hear it tapping side to side on the mount bearing.
Vintageracer
Jan 10, 2020 05:33 PM
Eric-86sc
Apr 3, 2016 03:52 PM
LittleFranks
Sep 17, 2015 12:22 PM
g.l.mos
Aug 22, 2015 12:02 AM
kyleb24
Aug 15, 2015 08:24 AM
