9 bolt swap for 10bolt 1LE change prop valve?
Old Mar 17, 2002 | 03:49 PM
formula355's Avatar
Just swapped out my 9 bolt from my 88 firebird with the performance package 350 for a 10 bolt with 1LE brakes; my firebird had 4 wd brakes do I need to change the Master cylinder and Prop. Valve or will mine work?? 10 bolt from a 92 iroc
Old Mar 17, 2002 | 06:35 PM
ANDYZ28's Avatar
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
Road test the car first. But you may need GM part# 14089496 proportioning valve.
Thanx,ANDYZ28
Old Mar 17, 2002 | 06:40 PM
formula355's Avatar
Would I be better off just changing the m/c and prop. valve from the 1LE car? I bought the whole car as aparts car and have everything?
Old Mar 17, 2002 | 08:58 PM
ANDYZ28's Avatar
Car: 1982 Z-28
EHHHH, WHAT!!!! You bought a 1LE car for PARTS? Do I have that right?
Old Mar 17, 2002 | 09:07 PM
formula355's Avatar
yes!!! the car was rearended 92 camaro rs b4c police package 1le performance package. everything complete except for a crushed drivers side rear quarter panel gave $800 for the car had the hotchkis panhard rod and trailing arm package, SFC, kyb shocks BFG drag radials, 10 bolt with Moser axles and Moser 3.73 gears, I have changed most of this to my firebird next project is to make my bird a five speed I came away pretty good huh?
Old Mar 17, 2002 | 10:23 PM
u r sofa king we tah did's Avatar
you *shouldnt* need the prop valve as long as you were originally equipped with discs. i didnt change mine when i went from 9 bolt to 10 bolt and the brakes are working just fine.
Old Mar 18, 2002 | 12:22 PM
ANDYZ28's Avatar
Car: 1982 Z-28
What " u r sofa king we tah did" said is correct.
Old Mar 18, 2002 | 07:35 PM
formula355's Avatar
Thanks for all of the info!!!
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
Terrell351
Jun 13, 2021 01:13 PM
Vintageracer
Jan 10, 2020 05:33 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
