control arms and panhard
Old Mar 17, 2002 | 08:29 PM
sllt1776's Avatar
Car: 89 Iroc-Z
i'm about to purchase some suspension mods and was wondering if anyone has hear of or used parts from BMR fabrication. They are cheaper in price over some other brands but are they comparable in performance. Also, does anyone know where i could find out how many 89 irocs came with aluminum driveshafts. thanks
Old Mar 17, 2002 | 10:42 PM
u r sofa king we tah did's Avatar
i think only the 1LE cars came with the aluminum shaft, so there wasnt that many. dont know about the BMR stuff though
Old Mar 17, 2002 | 10:51 PM
vic_V8's Avatar
Car: RS
Transmission: 4L60
I believe the their is a link on the homepage for the driveshaft numbers, not sure, in the tech articles it gives the rpo codes for it, get on the history board and search it, or just ask somebody knows.
BTW 1LE cars weren't the only ones with aluminum drive shafts
Old Mar 18, 2002 | 08:48 AM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
I have a BMR strut tower brace, and like it. The section that spans the engine is welded nicely without the quick removal bolts that some have. The braces that run from the main section to the firewall have adjusters on them. I have a SPOHN panhard rod and realy like it..although i will be upgrading to the adjustable version soon. Steve has very nice parts and is very active on this board so even if another brand is a couple bucks less, he will get my coin.
Old Mar 18, 2002 | 12:09 PM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: Pro-Built Automatic/Vigilante 2800
Hey Omega,
I've thought of welding one in instead of bolting but that would cause problems if I ever had to perform repairs like taking off the intake or head or something like that. Won't the BMR cause the same problems?
Old Mar 18, 2002 | 05:34 PM
Omega's Avatar
Engine: LS1 / LS3
grafx:
Eh, yes it will up to a point. It is not a quick removal version, but it can easily be unbolted. Its the same principal as the bolt in subframe connectors. If the front end flexes enough it will elongate the bolts and then render the unit useless. It doesn't take that long to remove the 4 bolts by the shock tower so i don't see it as being a big deal. The all in one unit also increases the torsional rigidity since it lacks the 2 removal bolts.
Hotrodboba400
Dec 10, 2019 07:07 PM
J-money
Jan 4, 2019 09:45 AM
Nick McCardle
Sep 10, 2015 08:36 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
