1LE rear brakes on a 9-bolt?
Old Mar 20, 2002 | 12:57 PM
TAZ28's Avatar
I have done a search and can not find a answer, but have seen a couple of people that have this in their sig. but they do not responed to emails.
So I have a 87 GTA with the 9-bolt rear end and am wanting to put on the rear 1LE caliphers. Is it just a matter of changing out the mounting bracket on the rear end and the new rotors and caliphers?
Ray
Old Mar 20, 2002 | 05:22 PM
PF Flyer's Avatar
Car: 87 T/A
Engine: TPI 350 ci
Transmission: 5 speed
what do you have for brakes now?
Disc, using the PBR calipers and an 11.7" rotor or drum?
Old Mar 20, 2002 | 10:06 PM
wuter's Avatar
You are going to need the larger rotors,calipers, new parking brake cable and backing plates. Good luck trying to find the PBR backing plates for the 9 bolt because they were only made in 1989.
Old Mar 21, 2002 | 10:31 AM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
The only difference between the 10 and 9 bolt rears is the backing plate. Everything else is interchangeable. GM has discontinused the plate so you will have to find it elsewhere.
Old Mar 21, 2002 | 10:39 AM
Metalifann's Avatar
I've got an extra set of 89 9-bolt disc backing plates. Email me if you need them.
Old Mar 21, 2002 | 10:49 AM
TAZ28's Avatar
I currently have disc brakes on the stock 9-bolt in my 87 TA GTA.
Metalifann email is on its way.
Thanks.
Ray
Vintageracer
Jan 10, 2020 05:33 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
kyleb24
Aug 15, 2015 08:24 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
