caliper question
Old Mar 29, 2002 | 05:51 PM
5 litre eater's Avatar
Car: '84 Trans Am
Engine: 350ci Sportsman heads, B&M blower
Transmission: Turbo 350
caliper question
Anyone know if front calipers will fit on the rear? And no, I don't care about the E brake.
Old Mar 30, 2002 | 10:51 AM
Car: '84 Trans Am
help...
Old Mar 30, 2002 | 12:21 PM
Hunter Motorsports's Avatar
Car: Camaro Z28 1LE R7U
Engine: 5.0 TPI
Transmission: G-Force Dog-Ring T5
It will require major fabrication - and it will mess up the brake proportioning. Anything is possible - but this is nowhere even close to a bolt-on swap.
Old Mar 31, 2002 | 09:08 PM
bryanwhite's Avatar
With some minor modification I think they will. If you have the older (82-88) rear disc setup (brackets anyway). The biggest problem is the line connection from caliper to rear end. The two calipers look the same side by side, except for one has the e-brake.
Old Apr 1, 2002 | 07:50 PM
BMmonteSS's Avatar
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
They will fit on the backing plates that much i know but i'm not sure what the added piston size will do in the way of upsetting your brake balance. With the money you save from using front calipers you could get an adjustabel proportioning valve to compensate. I went throught the same delima that you have when i retrofitted an 83 disk setup on my 9" for my monte. I ended up rebuilding the rear calipers so i can't vouch for the effectiveness of the front calipers.
sailtexas186548
Jan 19, 2016 12:21 PM
25thannivZ28
Aftermarket Product Review
Jan 2, 2016 05:41 PM
Genopsyde
Nov 11, 2015 10:46 PM
lt1z350
Brakes
Sep 12, 2015 09:28 PM
redmaroz
Aug 16, 2015 11:40 PM
