REAR DISK BRAKE HELP!!!...Anyone with them...w/in
Old Mar 31, 2002 | 08:36 PM
Kenwood's Avatar
Car: 1987 GTA
Engine: PT88 Turbo DART 406
Transmission: th400
Axle/Gears: 9" ford
OK I have a question....Im working on hooking up my new brake system in the rear and ran across an interesting (to me anyway) discovery.... WHY on my old 9 bolt rear is 1 disk caliper(pASS sIDE) Towards the front then the OTHER disk caliper (DRIVERS sIDE) TOWARDS THE REAR???
Is there any mechanical reason for this?? So far since finding this every other car Ive looked at either has both faceing foreward or both facing the rear......
When hooking up my new brake system would there be any disadvantage to having them both face foraward or backward OR should I just leave them the same....
I have to have new lines made and have a custom e-brake so Basically I will RE-Use NOTHING....
So starting from scratch....what should or could I do...
Any help on this would be appreciated...
Old Mar 31, 2002 | 09:55 PM
wuter's Avatar
i think they did it this way so u can use the same caliper on the left or right side
Old Apr 1, 2002 | 02:04 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Yeah, on my '84 rear calipers, if you remove the parking brake lever and bracket, the calipers look exactly the same from the back.
Vintageracer
Jan 10, 2020 05:33 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
cam-mike
Aug 24, 2015 07:23 AM
