Help! Rear End Is About Dead.
Old Apr 3, 2002 | 06:28 PM
rdog30's Avatar
Car: 85&95 Trans am
Engine: 85-LT1 95-LT1
Transmission: 4l60e & 4l60e
Axle/Gears: 3.23 & 3.23
The car has the 9-bolt disc rear and today going down the road it statred to hum really load. When you let off the gas it stops. The front seal is leaking on the differential so I opened the plug to add some fluid before it goes into the shop on Sat. It was only half a quart low, but there is metal shavings in the fluid. What could be going wrong?
Old Apr 3, 2002 | 09:12 PM
rdog30's Avatar
Car: 85&95 Trans am
Anyone? Come on.
Old Apr 19, 2002 | 10:02 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
It sounds like after 17 years of getting 'beat on' in the Trans Am the gears are simply getting worn out. I'm surprised that the POSI has held up longer than the gears !!
Your car is an 85 ?? I Know they put them in the Camaro starting in 87 but I thought that 86 was the first year for the 9-bolt in the Firebird ??
Old Apr 19, 2002 | 01:11 PM
rdog30's Avatar
Car: 85&95 Trans am
It had the 9-bolt. I just swapped it out and put a 98 3.23 posi 10-bolt in it from a camaro.
Old Apr 20, 2002 | 06:12 PM
Ringmaster72's Avatar
Car: 1989 IROC
Rdog, you have any pics of how much the back whels stick out now? Also, did you measure the rear to find out how much wider it is? I have heard anywhere from 3 inches to 5 inches, so which measuement is correct?
Tim
Old Apr 21, 2002 | 03:26 AM
rdog30's Avatar
Car: 85&95 Trans am
Sorry no pics. I have 4th gen. wheels also so there is no sticking out. The rear is only about 3" wider.
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
BlackBoulder
Aug 11, 2015 11:15 PM
