Will 1/2" Wheel studs fit on stock axels
Old Apr 3, 2002 | 10:41 PM
RED91Z's Avatar
Old Apr 4, 2002 | 07:20 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
No.
You can't stick a 1/2" diameter lug in a 7/16" hole.
But the axles can be drilled by a competent spring & axle type of machine shop.
Old Apr 4, 2002 | 11:16 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
how about replacing our metric studs(12 or 13mm)? with 7/16" studs ?
Old Apr 5, 2002 | 05:35 AM
PF Flyer's Avatar
Car: 87 T/A
Engine: TPI 350 ci
Transmission: 5 speed
how about these?
these are from GM
Attached Thumbnails Will 1/2" Wheel studs fit on stock axels-ta11.jpg
Old Apr 5, 2002 | 08:09 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Right... ours are 12mm, with the same shank IIRC as the older 7/16" studs had... kind of hard to pull a .500" thing through a .437" hole... but, a 7/16" stud is a few thousandths smaller than a 12mm one - very close, but smaller, so there's nothing to be gained by doing that.
Jeremys87
Jul 14, 2022 09:08 PM
italiano67
Dec 11, 2016 09:21 AM
camaro71633
Sep 1, 2015 10:24 AM
transaero
Aug 31, 2015 01:14 AM
greeny
Wheels and Tires
Aug 12, 2015 03:55 PM
